UpliftSxS custom gator
By Alex
What’s Included?
Why the RANGER XD 1500?
Entry Information
By marvin schuchart
Has anyone with a K9 2400 had issues your machine, My wife uses this one around the house. We have 60 pampered miles on hers and had a few issues. The master cylinder went out the 1st 30 miles, and again the master cylinder went out at 60 miles, I have been waiting for the dealer to install a new one for over a month now. the electric dump unit went bad at 55 miles, used it 5 times, window winder knob broke off handle on both sides, after a rain when I pull out it's a wall of rusty water that runs down firewall inside cab. Rusty water runs out tail gate when I lay it down, had to drill holes in bottom of tailgate to let rainwater out. I have a Polaris Ranger and a Kubota side by side, both have over 1600 hours and only had to do routine maintenance on these 2 old machines
By mrpro
My 2022 Coleman/Hisun UTV 400 steering shaft has a couple of U-joints and angles to help get it down from the steering column to the rack. Today, my son who drives it most came in and said that it wouldn't steer and that he could turn the steering wheel but it doesn't turn the wheels I investigated and noticed that the bolt that clamps down the upper part of the steering shaft onto the lower one before the first u-joint in the steering shaft had fallen out. We haven't been able to find it, so I wanted to see what size and thread, bolt I should get to fix it?
By Davescat
I have an 2019 Caterpillar cuv85. Which is the same as the prowler pro and the tracker800sx and prob many more. What is everyone doing for a lift? I need more ground clearance. I have seen 1 lift available. But is this the only thing I can do?
By hetovi
Hi everyone,
I’m considering installing a soft cab enclosure on my vehicle and wanted to get some insights from experienced users.
I’m particularly curious about which materials hold up best in different weather conditions and how to properly secure the enclosure to prevent leaks or wind noise.
Are there specific brands or models you recommend for durability and ease of use?
Also, how do you handle cleaning and maintenance without causing damage?
Any tips, tricks, or common mistakes to avoid would be incredibly helpful.
