    • By nrggaragebuilds
    • By jertex
      I have two questions:
    • By Bucky4444
      Has anyone found a decent replacement for the factory mirrors on a 2020 1100C?  My 2011 1100 and 2020 1100C both have the same mirrors and Kubota hasn't made one improvement to the design during those years.  Haven't checked the newer models so maybe Kubota finally woke up. Mine are definitely in need of improvement.  .
