Have a 2019 Coleman Outfitter 550.  only 30 hrs on it.    Just quit running.  Found the F8 fuse blown.  Replaced and blew again.  Traced ALL wires and found nothing.  Replaced all  relays and fuse so it starts up but hit the brake pedal and it blows the fuse again and will not start.   Retraced the wires and found nothing damaged.   Any Ideas?   Coleman is NO HELP at all
Since you've found nothing up to this point, I might suggest you check the tail light socket(s).  Remove the bulbs to see if the fuse blows again.  Could be a bad socket or a freak short in the bulb.
    • By Dave Jones
      So with seat belt on  I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By RBonds007
    • By RBonds007
      Looking for an online parts store.  Just need basic maintenance parts tune ups and such.  Any suggestions?
