You can post now and register later.
If you have an account, sign in now to post with your account.
Next problem with charging system to tackle, any help would be appreciated.
New starter solenoid....check
New Voltage Regulator...check.
Dynamic test to Stator.....bang...pulling like 2 Volts AC
Problem: Without pulling the part out and stranding the vehicle at the shop forever.... I am trying to find the correct stator or at least one that might not be exact for the Massimo Buck 400S, but fit and connect and do the job if that makes sense.... if anyone has any ideas, please shoot them my way.
Thanks a lot!
So with seat belt on I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
