2017 Yamaha YXZ 1000R SS Limited UTV Side by side Sport shift
    • By moto mutts
      Ahoy there, me hearties!
      Set yer sights on the grand spectacle known as the Shiver Me Timber SXS Fun Run! Cast yer lot with the crew of UTV Offroad Adventures as we embark on a daring escapade to seek both booty and trails in the Moabi Regional Park. This be where the Colorado River flows, a mere 11 leagues southeast of Needles, California. So don yer finest eye patches and make way with your trusty parrot!
      Behold, UTV Offroad Adventures proudly presents the legendary Shiver Me Timber SXS Fun Run! 'Tis an event that would make even the bravest buccaneers quiver with excitement! Aye, this three-day revelry promises a safe and organized escapade like no other. Venture forth and uncover hidden treasures aplenty as ye navigate your off-road vessel along waterfront trails, through shifting sand dunes, ancient bridges, and tunnels of yore. Come Friday night, there'll be a ride spanning a hearty 15 nautical miles. On both Saturday and Sunday, ye shall have the privilege to choose from two separate rides, ranging betwixt 50 to 90 nautical miles. And fear not, for the festivities shall include feasts, campfires, quick-draw poker, raffles, and an abundance of merriment, laughter, and revelry. This be an affair for sailors of all ages and UTV backgrounds. Join us in the quick-draw poker rounds, where every piece of eight we gather goes to aid local charities.
      Our epic off-road voyage shall commence from none other than Pirate Cove Resort. Nestled amidst the swaying palms and embraced by pristine, sun-kissed beaches along the Colorado River, all of this be situated upon the storied path of Historic Route 66. 'Tis an oasis where RV encampments and cabin rentals await, alongside UTV rentals and more treasures than ye can fathom.
      For those wielding mobile devices: For full event particulars, the location chart, the course itinerary, and to enlist yer name among the crew, set yer sights upon the Menu option above, arrr!
      Go to www.utvoffroadadventures.com for all the info
    • By johnpeter
      2022 Polaris UTV Utility Ranger Crew XP 1000 NorthStar Edition Trail On Ebay
      https://www.ebay.com/itm/225872999541?
    • By Tim Barbero
      I left my 2020 axis 500 UTV parked under the carport for about 6 months and when I went to start it recently a squirrel has built a nest under the throttle body and chewed through the efi harness.  I stripped all the wires back and reconnected them with waterproof butt connectors.  The problem I have is there is one blue wire with a red stripe coming from the main harness this wire has 5 volts dc showing on my multimeter but there are two blue wires with a red stripe coming from 2 different sensors on the throttle body.  I looked through all of the bits and pieces of wiring left behind and there’s no indication that the three wires of the same color were all tied together.  Any help with this issue would be greatly appreciated.
    • By Tim Nelson
      Ok guys, my turn...
      Working on my neighbors 2017 Massimo MSU-500.  Initial complaint was it would start and run for about 10 minutes and the just die.  He replaced the fuel pump and still had the same issue.  I stopped over one day to look at it and saw that it had codes flashing on the dash; 505, 336 and 337.  We decided to get a new stator/crank sensor.  Took it apart installed the new stator/crank sensor and nothing.  It won't even start.  I checked the pins on the crank sensor plug and one was in the wrong place, so I repinned it and it still won't start.  I double checked the connectors and all is good.  I checked the wires from the ECU to the coil, good.  It appears to have spark every once and awhile but not enough to start.  I replaced the coil with a known good one and still nothing.  I bought the cables and downloaded the ECU hardware and everything looks good.  I pulled the timing cover back off to check the flywheel keyway, it is good.  I checked the timing and timing chain, good.  I checked the valve lash, good.  I have to put it back together but just wanted to post in case there is something else I should check before hand.  I checked the 9 pin connector and it is clean.  I have battery voltage on the purple wire and pins 15 and 18 on the ECU.  I pulled the air filter off and I am going to put a new plug in it just for the heck of it.  What ECU inputs would prevent it from starting?  Why would it now not start at all after replacing the stator/crank sensor? It has to be something simple.  Any help would be appreciated.
    • Get More For Your Device
    • By KOmobileautocare
      I am looking for some parts for a customers 2004 Joyner renegade 800 and I was wondering if anybody knew who carry’s  differentials for replacements or rebuild kits for these or if anybody has one for sale
  • Gallery Images
