My 750 still start, and throttle up for a few seconds then die.  It will do this repeatedly.  It has fresh gas, a new fuel pump and a new ECU.  I've pulled the injector and it does not appear to be clogged. I have run out of ideas.
  • Popular Now
    • By BWF
      I am at a loss, please help!
      Brad
    • By esmarkey
      Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in.  It still acts like the belt is slipping but now I am thinking it is the clutch?
      Can the clutch be rebuilt?
    • By MilSurpYinzer
    • By Kierobi
    • By Butch
