  • 2 months later...
On 9/27/2021 at 7:50 PM, Jacob E freeman said:
I’m having the same issue with a 2017 550.  It’s in the shop now awaiting a new head gasket (that’s somewhere in neverland) according to shipping info.  Also a new water pump is to be installed.  Mechanics have repeatedly bled the system but after a few hours it overheats.   It has something to do with blow back.  Once it begins to overheat, the radiator and overfill jug is filled to the brim.   One mechanic opened the radiator cap and was drenched in the pressurized fluid!   The saga will continue if I ever see the head gasket.
  • 8 months later...
  • 11 months later...
I have a 2018 750 eps that overheats just like the guys in previous post..I was wondering what they did to fix it...I took to shop that I bought it from five or six times and they said it's fixed.. It's not . Anyone have an answer for me.. Thanks...
  • 4 months later...
I had the same problem. Shaved the head, new head gasket, new water pump. Nothing worked. I ended up just buying a new drop in motor. But as I thought about it, I never checked to see if the water pump was actually turning. I am guessing that the chain that drives the oil pump and water pump spun off. If I ever find the time I am going to disassemble the old motor and find out. 2018 750 challenger crew.
What drop-in motor did you use?  Have you been happy with it?
    • By Mountainman
    • By Jeff freeman
    • By Debbie Hogan
      Debbie fm  Texas
    • By HighSon
      Locking gas door.
      Rear view mirror.
      Folding armrests.
      Folding rear seats.
