Stumped on 2012 Massimo EFI MSU700 Issues
Popular Now
By rdc
By rdc
By Mitch13
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
By Kierobi
By Butch
