2022 Massimo buck 450
By AlphaSerenity
Hello,
By OBL
By Cliffampranch
By mehe
By Dave Jones
So with seat belt on I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
