  • 4 years later...
    • By Eman85
    • By Timbo
    • By Sharon
    • By hetovi
      Hi everyone,
      I’m considering installing a soft cab enclosure on my vehicle and wanted to get some insights from experienced users.
      I’m particularly curious about which materials hold up best in different weather conditions and how to properly secure the enclosure to prevent leaks or wind noise.
      Are there specific brands or models you recommend for durability and ease of use?
      Also, how do you handle cleaning and maintenance without causing damage?
      Any tips, tricks, or common mistakes to avoid would be incredibly helpful.
    • By riggy400
      Bought a Coleman 400 UTV (pretty much a Hisun), the previous owner tried to replace the timing chain, couldn't time it properly and sold it to me. After some hours I figured out how the timing all is supposed to be set (I think/hope) and as I am reassembling, I noticed that the water pump gear was awfully hard to spin. I held the gear with my hand and spun off the impeller. I checked the bearing, spins great no obvious issues noticed other than this o-ring which seems to be out of place? When I remove this o-ring and reassemble the WP, it seems to spin nice and easy without a drag. I looked up the service manual (although very inaccurate info there often) and don't see this o-ring present. Am I missing something here or what? Any input?
      This is not easy to access once the engine is back in the machine so would like to avoid having to deal with this if it becomes a problem.
