Posted (edited)
Hi I got a massimo buck 450 2022 and today I ran into a problem as soon as I turn the key on the backup alarm and the display in the dashboard shows me that it’s in reverse but the lever is in neutral and the  neutral green light is on and the motor won’t start, when I turn the key there is absolutely nothing. But if I put it in high gear the the display show me a H but as soon as I put it in neutral ,low gear or reverse it show me the R in the display but still won’t start any idea what is causing this issue??
Edited by Jocelyn Chiasson
  • Jocelyn Chiasson changed the title to Massimo buck 450 2022 Trouble with reverse
Try disconnecting the gear position switch on the transmission. Mine was messing up and thought it was in low. Don't really need it unless you like the BEEP!
    • By Adrian Domingues
      Thanks for your help
    • By jertex
      I have two questions:
    • By Eman85
    • By JohnnyB
