Hisun 550 dies when put in gear
By Xov
By Tim n Deb
By CaptainMorgan
I have a Bobcat 2200 Diesel (built by Club Car) with a 2-weight Team Primary Clutch I want to rebuild, possibly replace. The clutch has an annoying rattling sound at idle and appears the rollers and weights are worn and loose. When I opened it up, everything looks clean and in great shape. It's just that all the moving rollers and weights seem to have way too much play in them, possibly causing the noise. I've searched for clearance and torque specifications with no luck at all. The UTV has less than 500 hours on it. Any ideas?
By Wolfpaak
Thanks in advance.
Kenny
By Jon Spruill
