Replaced the injector, now when I turn the ignition on you can hear the fuel pump like normal but when the engine turns over it seizes up, pull the spark plug out and the cylinder is full of fuel, a lot of fuel, turn the engine over with the plug out and huge amounts of fuel blows out of the plug hole.   What have I done wrong?  I appreciate your help, thank you!
  • Popular Now
    • By AaronD1982
    • By Fmaxiron
    • By Kierobi
    • By Butch
    • By Jeff freeman
