Check your crankcase oil level, if it is too full then that means that your carburetor is leaking fuel into the engine when it is not running.  Your carburetor is overflowing to fix that adjust your needle and seat so that the fuel flow stops when the carburetor bowl is full.  The reason for gas being in the carburetor air box is that the crankcase breather is trying  to re-leave pressure because the crankcase too full (gas and oil).  Fix the carburetor problem and then change the oil.
Motojoe----I have to partially disagree with you on this one. That engine ( problably an EH65 ) has a 12vdc fuel cutoff which eliminates the float abd needle situation. That is on a two barrel carb. I'm not familiar with the single barrel.
OP needs to be more specific. Ed is this happening all the time or when running or when turning off? First thing is you need to take the seat belts out of the air cleaner. Lol..... That won't fix your problem! Describe in detail and how long this has been happening. Is the carb a single barrel or twio barrel.. We'll try to help `you.
    • By Sammy
    • By Jeff freeman
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Kierobi
      Have a MSU 500 that we got from my wife's uncle a while back. We've had it running and hauling around the property but it stopped a few months ago after what I thought was running out of gas and I'm just getting to looking into it.
      Had fuel to the injector but nothing coming out the injector so swapped with new injector and installed inline filter in the supply hose from fuel pump. Tried again and still nothing but noticed this time that I can't hear the fuel pump priming.
      Pulled off the electrical connection and I'm getting 12V to the fuel pump but it won't run. Put it on a test bench and got it to run so put test lamp between +ve and -ve terminals on the connector and nothing. Checked against the passenger seat securing post and get a light.
      Tried chasing the wire back and think that the ground is through the ECU but not 100% sure. Can someone confirm for me? And if it is through the ECU, is the ECU just grounded against the frame or is it wired through to the battery?
      Thanks in advance and hope this all make sense!
