This past week I was going over routine maintenance on my Trooper and decided to check out the crankcase breather/oil seperator unit and see if it need any attention. The thing is a mess. The fine dust from the desert where I ride hardly even slows down as it goes past the cheap paper filter under the nice chrome cap and enters directly into the top end of the motor. After taking every thing apart and blowing out dust and muck where oil mist from the engine combines with the dust running past the filter I decided to relocate the unit up into the clean air.
Although it looks like a chrome martini shaker mounted to the side of my roof rack I'd rather have people ask me what it is and tell them I drink alot than have all that dust being sucked into the engine. Pull it apart and take a look, I think you'll be surprised.
Happy Trails
Az Bound
I have more of a problem with it blowing oil out rather than letting it in, does yours stay dry?
Kinarfi
Mine was dry as a bone except at the point where it enters the head. Even at the nipple where it enters the head there was only on oil mist . All of the hoses had dust in them. The canister was dusty and the oil drain hole was clogged with dirt. In the hose fitting at the head where the dirt mingled with the oil mist there was about a 1/4" of crud. So it apears that mine sucks instead of blows. There was no oil in the canister. For me relocating the canister seems to be the best solution.
Happy Trails
    • By jertex
      I have two questions:
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By KMP
      We just bought our 1st side-by-side and wanted to get tips on maintenance items we should address immediately for our 2015 Arctic Cat Wildcat Sport 700 XT.  We are truly beginners and welcome any and all suggestions.  Thank you, we appreciate your help!
    • By jon pino
      having trouble with a 2013 uxv500i. have replaced stator due to bad pulser coil. new unit does not work. manual value for pulser coil is 100ish ohm, measured value is 500 ohm. can anyone with one of these fuel injected later model units check their pulser coil with an ohm meter for me? left side of engine small connector next to 3 yellows. jon 605-545-7040
