UTV Odes Ravager 1000cc - Strange noise from the back
By rtate1050
I know that this may be a bit outside the forum , but has anyone had any experience with all terrain wheelchairs ? I live on 5 sandy acres in Florida and am currently wheelchair bound. I have a power wheelchair but it doesn't work very well on my property . I.m looking at one that has rubber treads like a tank . It's pretty expensive so I was wondering if anyone had any experience or knows anything about them before I pulled the trigger.
I do have aa side-by-side but can't get in and out.
Thanks , Rich
By donny
Hello I am new here but have had this machine for about 5 years. I am having issues with it surging and sometimes sounding like a small backfire thru the intake. When putting in low, high or reverse it will struggle then go full power then struggle. It will only do the small backfire thing while in neutral reving it many times. Once in awhile it will throw a check engine light.
Parts replaced/checked:
I have checked the valve lashing, timing and adjusted. Parts replaced are the coils, spark plugs, injectors, fuel lines, fuel pump, IAC sensor, TPS sensor, throttle cable, speed sensor, primary and secondary clutch and belt.
By Alex
What's the best sport UTV / SxS? Varius opinions from the Can-Am Maverick to the Polaris RZR. A few videos that do a pretty good job on reviews and offering their thoughts on the best sport UTV / SxS on the market. 😁 Post your thoughts!
