power steering and rack & pinion parts
By Skeeter22
By Cliffampranch
By rdc
By Xov
By a4x4nutt
2021 uforce 800 turning radius is awful .
I just bought it added perfex lift
And 1.5 wheel spacers
The turning radius was bad before the lift .
I looked for steering stops under the tie rod boots and steering knuckle for steering stops . Found nothing .
Are the stops inside the steering rack ? Is there a replaced steering rack with longer throw to curb this issue ?
Any suggestions?
