Hi Guys we are taking the T4 to Marysvale for the Paiute UTV Jamboree August 13 for a Show and Shine (on Friday late afternoon and evening) then a ride on Saturday if anyone is there be sure to look us up!
Cinda
Had a great time! We met some super people and had some fun rides. There were lots of RZR's but we only saw one new Can Am and it was way to clean to have been out on the trail! We did see another T4!
They rent it out at Hoovers! Plus it was blue! Missed the Show and Shine, almost met a big rig a little close and personal on the way, I'm still not sure how George missed hitting him but going up hill outside St George we were in the fast lane when the trucker decided to change lanes almost hitting us. George was able to miss him by just inches, trucker had no idea he almost took us out. Luckily no one was behind us.
I needed to stop in Cedar City after that for a cold powerade and some advil!
  • Popular Now
    • By AaronD1982
      New starter solenoid....check
    • By Jamie 67
    • By AaronD1982
    • By Eman85
    • By Jeff freeman
