Can-Am to Sponsor the Paiute Trail UTV Jambore
By Cletus
Getting some work done on my sector 550 at a dealer, having issues with some parts. Dealer has tried, i have tryed, its been a month and hisun customer support has not emailed or called either one of us back.
Meantime my sector is sitting torn apart in the shop collecting dust. Apparently hisun doesnt give a ratsazz about their customers, anyone else having the same problem getting ahold of them? Sick of this crap.
By OBL
By Kyler
Put new fuel in this thing, new battery I can get it to turn over but want stay running it’ll try to run with starting fluid but shuts right back off what could the problem be?
By mehe
