I have a 1100 Sand Viper and recently have developed an electrical problem. When I turn on the ignition the fan is suppose to start but instead the relays start clicking. I try to engage the started several times and before the electric fan starts to run. At that point the starter will engage and the engine starts. On rare occasions the engine will turn over but will not start until the electric fan starts to run. Any ideas where to start looking will be appreciated.
Grounds. Start there, the look at your fuse boxes the wires burn up and make bad connections inside it. When you unbolt it you can look at the wires from the backside
When we were in Farmington, NM last summer at the Jamboree, Mine went completely dead. Finally ran a ground to the outside of my computer and everything ran fine. Never would run again without the computer being externally grounded.
Thanks for the input, I'll try your suggestions.
Thought I had already posted this, so here I go again, look through http://www.utvboard.com/topic/392-parts-pieces-and-information-for-our-troopers-joyners/page__view__findpost__p__475 and find the schematic and down load it and save for future needs, Also, you may want to remove the fuse/relay boxes and look at the back sides to see if you have any heated, melted wires, discolored connectors or fuse clips.
kinarfi
    • By Tim n Deb
    • By KWinTX
    • By Ed Michael
      Subaru SxS.mp4
