mule idle problem
By LongSun
By NDV45
I have 2008 Cub Cadet Volunteer Tracker. Was running fine, parked and next morning electric fuel pump inop. Checked voltage had 4.2 volts. Swapped relays in fuse box, checked all fuses (good) and still low voltage. Does the ECU control the voltage to the fuel pump or which relay controls the voltage to the pump?
Have checked all wiring and not found any place it could be shorted (not saying I may have missed something). I am at a loss. Need Help Please.
By great8redsfan
By Nathon S.
I have a Bennche 700 EFI Bighorn. I’ve recently been unable to get it to start. After a little troubleshooting I realized my fuel pump was not pumping fuel. This weekend I emptied the gas and replaced it with new. I replaced the fuel pump, fuel filter and fuel injector. I also replaced the battery, spark plug and made sure all my fuses and relays were good. I have confirmed that the float on the fuel pump is not obstructed. The UTV is about 12 years old and has less than 100 hours on it. It has not run in over a year. Not sure whats going on?!? After doing a little reading I'm leaning towards it being an issue with the ECU or perhaps a faulty wire in the wiring harness. Anyone have any ideas on where to start looking or what I could be dealing with? Any help is appreciated, thanks in advance!
