mule idle problem
By Tim n Deb
By monkthumper
By Ed Michael
My older LM 650 is blowing fuel into the air cleaner. Any idea on what would cause this? It is the Suzuki motor. Not sure what model year it is.
Subaru SxS.mp4 -
By Aaron Colona
Just bought a brand new 760 about a month ago. I'm at 20 hours which the book says is when you need to change the break in oil.
I must be crazy, but I can't find the oil filter. I've googled a million videos...everything seems to be 2019 or lower...and/or a 550. They all show the filter easily seen by looking in past the rear passenger tire on the engine. There is absolutely nothing there on mine.
1.there seems to be very little info if you Google a 760, or anything Massimo newer than like 2019.
2. Does anyone have a current model year 760 that can answer my riddle for me?
By Jon Spruill
