My intimidator is new less than 15 hours on it and it is overheating. Even on short rides less than 1 mile it overheats. Fan does not turn on at proper temps, checked relays and fuses and they check good. Any suggestions?
Bypass the temp switch .make fan run 100%..check oil for water in it. Look at recovery bottle while hot running for air bubbles.   Stuck thermostat.? Remove cap, see if coolant is circulating.? Water pump working?
  • 11 months later...
    • By Mountainman
    • By mehe
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By carbdoctor
      I have an 850. It’s been overheating. The electric fan is not kicking on. I see the temperature switch going into the radiator, but there’s no wire plugging in to it or none to be found in the area. i’m thinking I might’ve hooked on a branch and it ripped out the harness on that part. Does anybody have a picture or no where that plugs into on the harness? On the top of the firewall, I did notice some plugs that have nothing plugged into it. I was wondering if it’s a harness that goes from there down to the radiator that was pulled off
