IMHO our fuel is subject to price fixing by a monopoly of a few. I posted this on rv.net of which the site quickly took down / deleted. Big business is really out to take advantage at every turn. rv.net is owned by the same holding company that owns Camping World. So much for free speech. They own everything you post. That is why I will never go on ANY Social Media site.
http://www.npr.org/2...surpass-imports
rocmoc n AZ/Mexico
A good reason to have a Jamboree SOB, (South Of the Border). Fuel is 1/3 to 1/2 cheaper. Of course you will have to pay thu the nose to get to the border.
rocmoc n AZ/Mexico
    • By Sammy
    • By Jeff freeman
    • By mehe
    • By Kierobi
    • By Butch
