  • 3 years later...
PM Kinarfi,
I have a 2008 T2, that I got as a project. I have been trying to read as many posts as i can to find answers to my problems. I think some of the things you have done will be of great interest to me, but I don't know how to get them.
How do i find you when i go to the above site (Webshots). I sign in, but don't know the next step.
Thanks, Charlie
PS, your electrical skills are truly amazing.
this is a PM I sent to Lugar32, just in case it may help someone else, he has an 08 that's missing it's fuse blocks and needs to replace them.
http://www.utvboard....15-fuse-blocks/have you looked at this? What supplies do you have? such as wire and fuse block and fuses and such? I suggest a piece of aluminum such as a 3" x 36" x 1/4" bar or channel for mounting your fuses on, I suppose they took you blinker flasher too. I also suggest, 12 each, IFR4095 P channel FETs, 5K 1/4W resistor,4-40 screw, washer, lock washer, nut, Transistor Rubber Washer TO-220, Insulation Bushing TO-220 and MAYBE 12 2N2222 NPN transistors and 12 1K 1/4watt resistors. Do you have a place to get this or do you need a list to send to an on line seller?
PS 1/4 watt or 1/8 watt or 1/10 watt resistors are ok, your choice
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By gridlock
      After three years, my Sector completely died.  Something caused the hot wire under the seat from the charger to disintegrate, so the batteries weren't being charged.  The batteries weren't charging 100% anymore, so decided to convert to lithium.
      As most others have done, I went with 4-48v batteries in parallel, as I believe that will be plenty of amp-hours for my needs, but can always add more if needed.  I went with LiTime wired CAN batteries and mounted their digital gauge on the dash above the current one, which fit perfectly.  I didn't think the existing battery brackets worked well for the new batteries, so made my own out of aluminum L rails, which makes it much more secure (and saves a few more ounces :)).  Since I wired them in a 'balanced' configuration, I had to make all new cables from 0/1 gauge wire and 8mm posts.  I updated the DeltaQ charger to profile 233. Cleaned everything up (I must have vacuumed 20 pounds of dirt!), put it all together and... wham!
      So far, it definitely is better than with the original AGM batteries.  Sustains speed better going up hills, and seems to have plenty of reserve current.  The difference in weight with 4 LiPo vs 8 AGM batteries surely doesn't hurt!
      A few questions:
      In the 'any tips' thread, EVSupport mentioned reprogramming the Sevcon to reflect the new discharge curve of the lithium cells, but I didn't see any more info about that or how to do that.  Is there any more info about that?
      Have folks replaced the onboard 12v battery, and if so, with lithium?  I'm not sure why there is a 12v battery; why didn't they just step down the current of the 48v system to provide power to accessories?
      Is there a recommendation as far as charging with the lithium conversion?  As far as I understand, it is better to let lithium batteries discharge somewhat (but not completely) than keep them charging all the time.  What do you think?
    • By Dewayne jones
    • By Jamesshoop1
      This was happening to me regularly with the original battery pack, I would drive a few yards and power cut to the motor, no error code, dash works, lights etc, just no drive. Brake lights not on so I don’t think it’s a switch thing. Sometimes it would go back to normal after a few day sitting in the barn. I ended up changing to lithium ion battery 100amp 48v and the problem completely went away for two months so I figured it was something worth the old battteries. Now it’s doing the same thing again, I’ve removed every main electrical connection, cleaned it good, and put it back together. Battery is at100 percent and good voltage. What is interesting is it doesn’t matter how much power I’m drawing, if I’m just creeping along in low or flooring it in high it stops after the same amount of time, about 7 seconds. If I let go of the acceleration right before the 7 seconds I can keep driving like that indefinitely but obviously that’s pretty annoying. Or if I switch immediately to reverse I can back up  and go back to F without cycling the key. Has anyone else run into this? It really seems like a safety switch issue to me but unsure what else to check.
