Ok guys us eastern riders need to get together. I ride with a guy with an rzr two custom golf carts and lots of quads. I'd like to meet and see some other Joyner people and buggies! I went to north strafford nh a few weeks ago with a large group and it was great 120 miles of trails and the views were great! We are planning on a trip next yr to jericho state park nh . It will be toward the end of June they have a big mud run there and obstacle course. The festival is two days my group is going to do atleast 3 nights 4 days. From my house in ply ma it's 5 hrs there's no camp grounds at the park but there is all over town! Here's the good part you have to register with nh 38 for a mounth pass but once u are registered you can drive your Joyner quad or whatever right threw town meaning Dunkin doughnuts gas pizza or whatever!
not sure if anyone will be into this but heres some more info. Jericho fest is july 27-28 its a friday and sat in Berlin Nh there is 375 acres and lots of trails wits a utv and quad fest with competions and just general riding. I dont think there is a a fee for watching but there is for competing. You have to reg in the state of NH mounth pass is 38$ or a yr is 75$, need vin # color make model cc of vehicle there is plenty of campgrounds and a few hotels close by once you are regiestered with NH you can drive you vehicle threw town gas sations resturants and so on. Cederpond campground looks the best so far and the price is resonable. I am planning on going up the 25 that eveing or early on the 26th wich is a thurs and then leaving that sunday or monday
  • Popular Now
    • By Sidewinder
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
    • By Jody Deville
    • By gridlock
      After three years, my Sector completely died.  Something caused the hot wire under the seat from the charger to disintegrate, so the batteries weren't being charged.  The batteries weren't charging 100% anymore, so decided to convert to lithium.
      As most others have done, I went with 4-48v batteries in parallel, as I believe that will be plenty of amp-hours for my needs, but can always add more if needed.  I went with LiTime wired CAN batteries and mounted their digital gauge on the dash above the current one, which fit perfectly.  I didn't think the existing battery brackets worked well for the new batteries, so made my own out of aluminum L rails, which makes it much more secure (and saves a few more ounces :)).  Since I wired them in a 'balanced' configuration, I had to make all new cables from 0/1 gauge wire and 8mm posts.  I updated the DeltaQ charger to profile 233. Cleaned everything up (I must have vacuumed 20 pounds of dirt!), put it all together and... wham!
      So far, it definitely is better than with the original AGM batteries.  Sustains speed better going up hills, and seems to have plenty of reserve current.  The difference in weight with 4 LiPo vs 8 AGM batteries surely doesn't hurt!
      A few questions:
      In the 'any tips' thread, EVSupport mentioned reprogramming the Sevcon to reflect the new discharge curve of the lithium cells, but I didn't see any more info about that or how to do that.  Is there any more info about that?
      Have folks replaced the onboard 12v battery, and if so, with lithium?  I'm not sure why there is a 12v battery; why didn't they just step down the current of the 48v system to provide power to accessories?
      Is there a recommendation as far as charging with the lithium conversion?  As far as I understand, it is better to let lithium batteries discharge somewhat (but not completely) than keep them charging all the time.  What do you think?
