4 lug to 5 lug???
Looking at the lack of options that are off the rack. Finding more headache than I care too. I was wondering about doing this type of swap. has anyone attempted/done this what the result were? I have 2012 T2 and my wheels are 4x108mm (4.25in). I can't find crap. I do more on and off-road with the T2( I'm street legal) due to hunting and such. So I was looking to upgrade.
Sorry I have not been active like I should: moved, kitchen remodel, table saw with fingers.......couldn't do a whole lot of computer time.
Here are the pics. of the rear wheels and with tape held close to it. Had to start at 2inches due to fingers. Only had one good hand, but 2 to 5 1/4 still equals 4 1/4(or 108mm). Please correct me is my math is off. I may not be the sharpest tool in the shed but I can still do work.
    • By great8redsfan
    • By Mark T
    • By ETHIEL
      Spark plug keeps fouling. after 10-15 minutes of running any ideas what to look fore
    • By johnpeter
      2023 Can-Am Maverick Sport XMR 1000R RED TITANIUM On Ebay
      https://www.ebay.com/itm/156096225938?
    • By FloridaMan
      I have a 2012 Massimo MSU 500 that died. I found that it didn't have spark and the fuel pump wouldn't run. Checked all fuses and none were blown.
      Went through and replaced the ignition coil, HT lead and spark plug. Still no spark.
      Thought it could be the fuse/relay box because I didnt' know much about the machine at that point so I replaced it. No spark.
      Then I replaced the ECM just because I was running out of ideas. No spark.
      I removed the 9 pin connector and hardwired it making sure that they were no wires got swapped. Still no spark.
      Then I replaced the wiring hardness. In doing so, I replaced the 9 pin connector with new ones. I made sure all wires were matched up between the engine harness side and the other harness assembly. Still no spark.
      I have no other ideas what to do. My fuel pump doesn't kick on and I have no spark. I have 12V on the fuel pump, ignition coil and fuel injector, but no ground from the ECM control.  I unplugged the fuel injector and waited for a diagnostic code but nothing ever came in. It makes me think that the ECM isn't powering up. I've checked for 12V on pins 18 (purple wire) and 15 (white and black wire). I also checked for ground on pin 2 (black wire). All are good.
      I am out of options here and I have no idea what else it could be. I have all connections redone and are coated with dielectric grease. I've checked all easy things like fuses and making sure I have 12V in the right placed. I would appreciate any help.
