4 lug to 5 lug???
By TomW
I had a problem 6-8 mo ago when the unit would not start . But you could see power on the dash. The starter solenoid was replaced and it has been fine until yesterday. When I started it up I noticed a high pitched noise coming from under the front. Like a alarmbuzz ..It seemed to drive fine so I went ahead and used it off and on for a hour or so . The noise would not go away . I parked it in the shed and lifted the hood . It seemed to be coming from the battery compartment ( where the new starter solenoid is) I jiggled the connections and the noise changed timbre and then the machine went dead. No power at all . No lights . When you cross the two poles on the starter solenoid ( previously last year it would start and run ) nothing. Checked the battery and it is fully charged . I checked the fuses inside the battery box and they all looked good but I must be missing something. Anyone have a clue what I need to do next to R&R. The closest repair place is 2 hours away in Mississippi . Any help would be appreciated.
By great8redsfan
By FloridaMan
I have a 2012 Massimo MSU 500 that died. I found that it didn't have spark and the fuel pump wouldn't run. Checked all fuses and none were blown.
Went through and replaced the ignition coil, HT lead and spark plug. Still no spark.
Thought it could be the fuse/relay box because I didnt' know much about the machine at that point so I replaced it. No spark.
Then I replaced the ECM just because I was running out of ideas. No spark.
I removed the 9 pin connector and hardwired it making sure that they were no wires got swapped. Still no spark.
Then I replaced the wiring hardness. In doing so, I replaced the 9 pin connector with new ones. I made sure all wires were matched up between the engine harness side and the other harness assembly. Still no spark.
I have no other ideas what to do. My fuel pump doesn't kick on and I have no spark. I have 12V on the fuel pump, ignition coil and fuel injector, but no ground from the ECM control. I unplugged the fuel injector and waited for a diagnostic code but nothing ever came in. It makes me think that the ECM isn't powering up. I've checked for 12V on pins 18 (purple wire) and 15 (white and black wire). I also checked for ground on pin 2 (black wire). All are good.
I am out of options here and I have no idea what else it could be. I have all connections redone and are coated with dielectric grease. I've checked all easy things like fuses and making sure I have 12V in the right placed. I would appreciate any help.
