rear diff
toddlong
Go to solution Solved by Kinarfi,
ok well my locker was nt working properly so i tore everthing apart and found that the two gears that was side by side where the gear slides over top of them to engage it had a lot of play in it took the bolts out of the ring gear to find out that 2 bolts was snaped and that most of the rest of them was worn or deformed .... what is the upgrade kit consist of and i m going to get new bolts tomm from tri corps or fasten all ...i have another rear end that i am using parts from that the two gears are very tight on
Yeah get new bolts & lock tight the hell out of them. If you can safety wire them also that would be even better if you know how to properly safety wire. The kit has upgraded bolts which Lenny machined the heads on and shims. The biggest upgrade being the bolts & liberal use of high temp lock tight.
The stock bolts wiggle loose then shear off. If they stayed tight no one would have issues most likely.
red lock tight i got napa to order the new bolts today and yeah i m pretty sure i can drill some holes threw the new bolts and wire them up .... i was disappointed when i found out they did nt have anything harder than a 8.8 the only ones i could find in the right thread was to big of a head ....
Are the head 10mm and shallow? Regular bolt heads won't clear, search for McMaster and follow them, I did a right up on what you need and how to grind the heads down to clear, Red lock tite is good, but yellow is a better. Find the post that says to use shanked bolts and there are instructions in there too. good luck.
Jeff
it is an 2008 as well and i tried tri core ... fastenal and napa .... IRC in ohio is where i got the right bolts .... but the head was a 13 mm vs a 10 so i had to cut it down
sorry i did nt take any pics it is back together and locking in and out and running smooth
Get some loctite too http://www.utvboard.com/topic/2795-tapered-roller-bearings/?p=16079 this is what I used on my bearings, but it's probably good for your diff too.
And while I'm here, may I suggest that every time you have a wheel of the ground, push and pull on the top of the tire and see how much play you have.
IMHO the two worst problems with the Trooper are the diffs and the wheel bearings, get the roller bearings, repack the grease and loctite them in place
I had a couple of bearing fail, but I got right back on the road because I had most of a spare and it had the right parts in it. I like the idea of the shank on the new bolts extending through all the separate pieces so you don't have a place for shearing to start, plus this is the strongest bolt you can buy, 12.9, and NO, I haven't had any problems since. I think if you get thing tight and loctited, you can put it on your do not worry list, you did read about Lenny's instructions to sand all mating surfaces radially, right?
    • By A P
    • By Brett
    • By Browner010
    • By shawn b
    • By Isaac
      I have a 2013 odes dominator when I get in it.  It ideals fine but when you give it gas it bogs and goes and bogs and won’t go passed 30 can anyone help me
