Radiator Fan
By AndySwish33
Brand new t boss 550. couple of questions.
1. Do you need speakers in order to play music ? Hooked my phone to Bluetooth no sound
2. On screen registration.. it won’t let me fill in the info on the touch screen. Navigation works but the registration portion does not
3. Is there a data plan you can get or need ?
thanks everyone
By joeam
I have a 2018 TW450E that runs in my yard and slow good just will not go down the road seems to be running out of fuel where should i start? I have replaced both fuel and air filter drained gas and tried a small auxiliary tank same issue i have ordered a new vacuum fuel pump to try next anyone in Texas that works on these?
By Nathon S.
I have a Bennche 700 EFI Bighorn. I’ve recently been unable to get it to start. After a little troubleshooting I realized my fuel pump was not pumping fuel. This weekend I emptied the gas and replaced it with new. I replaced the fuel pump, fuel filter and fuel injector. I also replaced the battery, spark plug and made sure all my fuses and relays were good. I have confirmed that the float on the fuel pump is not obstructed. The UTV is about 12 years old and has less than 100 hours on it. It has not run in over a year. Not sure whats going on?!? After doing a little reading I'm leaning towards it being an issue with the ECU or perhaps a faulty wire in the wiring harness. Anyone have any ideas on where to start looking or what I could be dealing with? Any help is appreciated, thanks in advance!
By moonrover
Mine is overheated/burned/melt at connection with its wire connector, parts are ordered to replace both them. This seems to be a common issue, and some of you already replaced it. I right now just connect the wires, so the fan runs all the time whenever the initiation is on, but it's better let fan runs as needed with a working temperature sensor/switch.
Question: Does some coolant come out by removing the switch/sensor from radiator? Or, is the threaded hole all the way inside radiator? If the answer is yes, I want to drain or extract some coolant to make its level below the sensor before replacing it, so I don't make a mess with coolant spilled out
Thank you.
By Hugh
Cooling fans are working, I can hear it running once awhile if I can get the engine warm up enough. Thank you for all the help.
Hugh
