Turbo Oil Restrictor
By Tim n Deb
By Chile
Chile
By Prepper
I have been doing a little research on which engine oil is best for UTV engines. There seems to be some disagreement over using a good quality regular engine oil, and the necessity of using "M2" (or wet clutch suitable) oil. My understanding is the "wet clutch" suitable oil has less friction reduction properties (hence a more responsive clutch with less slippage). While less friction reduction properties would seem to be better for the wet clutch... it would not be best for the internal engine parts like camshaft bearings and other moving parts where friction is detrimental and would lead to premature failure. Some folks swear you need M2 oil, while others say they have been using regular motor oil for years and their clutch is just fine. Could they both be right ???
Any thoughts ?
By Joe Breaux
Decided to do an oil change on the Massimo ...drained oil, screen was very clean even tho oil wasn't. Then went to remove old filter.. holy crap ..I tried every tool I have, could not budge it..Went to store and got one of the end cap type..fit nice and tight, put a 1/2 in drive ratchet on it..nope..not moving. Put a 18 on breaker bar o. It. The inside of the removal tool broke off!! Had to weld it back together. Put a pipe on the bar for more leverage. Finally broke it loose..
I have never seen a filter in my 55 yrs of working on engines so tight..And i was the one who put it on 2 yrs ago. JUST HAND TIGHT!
By davebuckholts
I just picked this UTV up off of Marketplace. It needs batteries.
I am installing a single 48v lithium battery.
The on board charger, a NOCO Genius GX 4820, has a lithium mode.
Has anyone here used this charger on new lithium batteries? I want to be certain of the compatibility before hooking the charger to this expensive battery. **
I got in touch with NOCO and they told me the charger is fine to use on a new LiFePo battery.
Nice charger. Many modes. New ones are running about $550.
