Confused on relay wireing
By OBL
By mike28honda
By Alex
What’s Included?
Why the RANGER XD 1500?
Entry Information
By HighSon
Locking gas door.
Rear view mirror.
Lowered and modified headrest bar for improved rear view. Tailgate protector.
Folding armrests.
Overhead utility rack. Keeps the interior cooler and dryer, too!
Folding rear seats.
If anyone wants links to the rear view mirror, seats, or arrests, let me know and I will post. But know that everything requires some level of fabrication. The utility rack was all custom built. Cheers!
By Fmaxiron
Thanks a lot!
