I have a 450 sector, the main relay is located under my seat in the battery compartment. It's a little hard to see due to being crammed down in a hole. It has 4 wires.
Hope this helps
    • By Fmaxiron
      Thanks a lot!
    • By Garjess
      My rtv 1140 won't turn over.  I've jumped the neutral switch, and the brake switch, and checked the ignition switch. I'm not getting any power to the trigger wire on the starter solenoid.  It starts fine with the key on and putting power to the trigger wire on the solonoid.
    • By Burk
