    • By Flanman55
      I have purchased a used Supermach700 (2008), It runs great after a new choke cable but. The temp sensor on the thermostat house is unhooked and can not find where it plugs back in. The fan has been un hooked from the sensor in the rad and cant figure out how it goes back together properly.  The fan was wired to a by pass switch and i just always leave it on but would like to work it properly. I assume the sensor went bad and not changed.
      any help would be great.
      thanks
    • By GunnersTacklebox
    • By Some random dude
      2015 Hisun 700 Utv
    • By Bbicon
      I have a 2014 odes 800 dom. I  have a wire in the same harness as the fuel pump plug ( just before it ) and it is not connected to anything t has a connector and a little brass connector on the end , I was wondering if anyone could tell me where it goes to
    • By Dennis
