Any Kioti K9 2400 owners joining for class action?
By Xov
By Flanman55
I have purchased a used Supermach700 (2008), It runs great after a new choke cable but. The temp sensor on the thermostat house is unhooked and can not find where it plugs back in. The fan has been un hooked from the sensor in the rad and cant figure out how it goes back together properly. The fan was wired to a by pass switch and i just always leave it on but would like to work it properly. I assume the sensor went bad and not changed.
any help would be great.
thanks
By GunnersTacklebox
By Bbicon
I have a 2014 odes 800 dom. I have a wire in the same harness as the fuel pump plug ( just before it ) and it is not connected to anything t has a connector and a little brass connector on the end , I was wondering if anyone could tell me where it goes to
By Dennis
