Identify this part help needed
Go to solution Solved by mixfixdave,
Thanks in advance.
Kenny
1 hour ago, mixfixdave said:
Post the link if that IAC works for you please…
Sent from my iPhone using Tapatalk
There was quite a selection to chose from. Have you tried any of them and they didn't work? I just searched for  "idle air control for an 800cc chery engine".
On 4/19/2025 at 9:27 AM, mixfixdave said:
I have not.
I cleaned mine a few times then unplugged it last time it got sticky.
I unplugged mine and it wouldn't start and run. Kind of fired a little bit but wouldn't catch. Should it have started and run?
If the IAC is closed, the engine should run.
Yours is stuck open most likely.
I would take it out, clean it and make sure it is fully extended.
I’ve heard you can make a plug for the hole and a block off plate if you want to leave the IAC removed.
    • By nrggaragebuilds
    • By jertex
      I have two questions:
    • By OBL
    • By Nick Varnes
