2012 4by4 himun utv
I found another forum that had someone with a similar problem and found this reply,
"there is no way to disconnect the limiter,
The engine is designed to rev as high as it can without causing damage, if you were to make it rev higher, the valves would float and come into contact with the piston,"
    • By TomW
      I had a problem 6-8 mo ago when the unit would not start . But you could see power on the dash. The starter solenoid was replaced and it has been fine until yesterday. When I started it up I noticed a high pitched noise coming from under the front. Like a alarmbuzz ..It seemed to drive fine so I went ahead and used it off and on for a hour or so . The noise would not go away . I parked it in the shed and lifted the hood . It seemed to be coming from the battery compartment ( where the new starter solenoid is) I jiggled the connections and the noise changed timbre and then the machine went dead. No power at all . No lights . When you cross the two poles on the starter solenoid ( previously last year it would start and run ) nothing. Checked the battery and it is fully charged . I checked the fuses inside the battery box and they all looked good  but I must be missing something. Anyone have a clue what I need to do next to R&R. The closest repair place is 2 hours away in Mississippi . Any help would be appreciated.
    • By Randyh79
      Is there a way to adjust the brightness of the dash light on aHisun 750 sector?
    • By todd93
      Hi, all! I. I'm new to the board, hoping someone could help me out! I have a 2020 Hisun Sector 550C that I bought new in 2021. Today, I took some stuff next door to my parents. When I went to leave, I turned on the key, heard the solenoid click, but no lights, no guage activity, no fuel pump, and no starter.
      The battery is good, I checked all the fuses, they are good. Not sure if the relays are good, or even what to look for there. Is it possible that it's maybe a wire?
      I'm really stumped on this one! Any help would be deeply appreciated! Attached is a pic of the fuse box layout.
      Todd
    • By donwan
      View File 2017 Hisun Strike 900 Service Manual
      Here's the service manual for the 2017 hisun strike 900.
      Submitter donwan Submitted 05/29/2024 Category Hisun
