I have a 550 colman and i am trying to get running as it came from another military base. It came without keys battery and all fluids drained. So how can i bypass key switch and can i use a temp battery to start it. I want to make sure it runs first before i replace key parts. I added oil, brake, antifreeze still working on other fluids. not sure if i am missing any electrical partsBattery in picture is junk i think. not sure what the connector is. probably will have to buy an ignition cylinder in future. So any guidance is appreciated.
The head gasket seems to be leaking. Sprays antifreeze out of spark plug hole when cranking which I am pretty sure motor is probably toast. Is it worth fixing or where can I get a replacement motor?
Do you have any mechanical experience? The fluids were probably drained because the head gasket was blown. The engine may be fine, just needing a new head gasket. Drain it all again, oil and antifreeze and pull the head and see how it looks. Get a new gasket and put the head back on noting the torque requirements. I do recommend taking the head to a trusted machine shop and have them check the flatness of the head before re assembling. They can plane a couple thousands if necessary to flatten it.
    • By Sammy
    • By Adrian Domingues
      Thanks for your help
    • By OBL
    • By mfitzner
      Have spark and fuel pump runs
