2013? TW400 GX390RT2 GCBCT 4 prong ignition coil replacement wire connection
By didgeridoo
By Cliffampranch
By AaronD1982
By lincolnsq175
I have a 2020 coleman ut400.
Any info is appreciated.
By Mitch13
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
