I've had my Hisun Sector E1 for nearly 4 years - only used a few times a week for less than 10 minutes, finally gotten around to doing an oil change. There are 2 oils that need to be drained and replaced. I found two plugs underneath, undid the one closest to the front, drained almost a liter of oil, so knew that was the GL5 oil to replace. Finally figured out where it was supposed to go, put in new oil, did it up, then opened the drain plug closest to the rear (underneath the vehicle), and I'm pretty sure the oil that drained out was the oil I just put in. Filled it again with 900ml  and hunted around for a third plug, but so far: no joy. Am I missing something? Is there another drain plug I haven't found?
The manual is not very specific - the pictures don't match the actual vehicle exactly, which makes this quite challenging
I haven't changed the front and rear diff/gearbox oil either, but from the manuals I've seen there isn't any tie between the front and rear at all, and the front shouldn't be a whole liter. What makes you think the rear fluid is from the front?  I feel like there's a chance that if the UTV hasn't been driven that much, the fluid might not look very used.
  • Popular Now
    • By Burk
    • By Jamie 67
      Why is there 2 different length keys for my tboss 1000?
      Can anyone please tell me or send a link as to how & where to hook up a code reader to my 2021 Hisun 500 Axis.  I have a 6 pin to a 18 pin  adaptor and the blue cord VAG KKL adaptor .Just not sure where or what to hook up to. Can I use your typical vehicle code reader or do I need to download something on a laptop or PC???
    • By RBonds007
      I bought this SxS brand new.  A couple of years after I bought it, I became disabled.  Thus it has only 47 miles and around 16 hours of use.  I have no need to keep the SxS.  I am in Foley, Alabama.  It is very hard for me to get in out of the Challenger.  I would like to sell the set, 2019 Challenger 400, trailer and uninstalled winch (this was bought brand new as well, someone was supposed to help this newbie install and we never got around to doing this). I want  $6500 for the whole set OBO (Serious offers only).
