Fuel pump fused on a 2022 t boss 550?
Popular Now
By potts
Not my machine T boss 800 Massimo, < 300 hours will not shift at transmission, cable from selector knob is okay, cannot get it to shift at the transmission. Is there a safety one of the safeties I'm not holding in, I've tried the brake is something weird going on or is it Transmission problems.
By Jeff freeman
I have a Coleman 550. Was having problems to start with where it would start and then shut off after a couple tries. It would take off and be good. It then got to a point where it would not start at all. I replaced the fuel injection twice the second time I replaced it I noticed a mouse or something had chewed one of the wires that connect the electrical to the fuel injector. . So two-part question first does anybody have a part number for that wire harness? Second, any other ideas after I fix the wire harness permanently on what could keep it from starting I have gas flow up to the fuel injector.
By Debbie Hogan
I realize this part is discontinued but im trying to find this exhaust pipe fir my dads 550. His brother who has since passed bought this mule for my dad who is now 90 and he is trying to fix everything on it. I'm willing to take a used one. A new one would be great if someone still had in stock. I'll take anything as long as it is in workable condition. If anyone has any ideas for me im open to hearing them. Thank you so much.
Debbie fm Texas
By Kierobi
Have a MSU 500 that we got from my wife's uncle a while back. We've had it running and hauling around the property but it stopped a few months ago after what I thought was running out of gas and I'm just getting to looking into it.
Had fuel to the injector but nothing coming out the injector so swapped with new injector and installed inline filter in the supply hose from fuel pump. Tried again and still nothing but noticed this time that I can't hear the fuel pump priming.
Pulled off the electrical connection and I'm getting 12V to the fuel pump but it won't run. Put it on a test bench and got it to run so put test lamp between +ve and -ve terminals on the connector and nothing. Checked against the passenger seat securing post and get a light.
Tried chasing the wire back and think that the ground is through the ECU but not 100% sure. Can someone confirm for me? And if it is through the ECU, is the ECU just grounded against the frame or is it wired through to the battery?
Thanks in advance and hope this all make sense!
By Butch
I have a AXIS 700 EFI Fuel pump pressure stays at 40 psi and when return line is blocked the pressure goes to 60 psi. and wll only run with return line closed.
