Hello all. Just bought a 2006 Joyner 650 SAND VIPER and have been going through it quite a bit. Have a hard time finding parts for it so I've been going with a lot of universal parts including the trailing arm bushings I'm swapping out for 1.5" poly bushings with sleeves. Original bushings did not have inner sleeves which is terrible design flaw. I am also having trouble with the oil warn light coming on after replacing oil and driving it a week it intermittently pops up. No pressure gauge but I have one on order. What type of oil do yall run I put 10-40 in it but heard 15-30 is recommended by manufacture? Also in need of rear wheel bearings but the part compatibility list stickied in the forums suggests part numbers for sand spider however the viper is similar frame to the 800 series with the trailing arm style suspension in the rear. I will dismantle the hub this weekend to take some measurements just seeing what general knowledge is out there. Thank you
    • By nrggaragebuilds
      2004 250DL DIRT DEVIL. Hey y’all, I already know this is a long shot. But I am looking for a the “prick gear” assembly that makes reverse work for my external reverse gearbox. OEM PN D250.08.103 and its assembly. I bought the kart as a basket case, but I saw that the reverse box was present so I was optimistic.  Upon starting working on the buggy I realized there was a block off plate in plate of there the normal gear would be. If my understanding is correct that means the transmission no longer has reverse gear. I figured it’s just a standard bevel gear and I could probably find a gear to make work, but I don’t want to spend the time making all the other housing parts to shim the gear perfectly. Has anyone spare parts, or figured out an aftermarket solution from McMaster? I already know it’ll be a challenge to get this box to be happy again, but figured I would ask
    • By Fmaxiron
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
