    • By jertex
      I have two questions:
    • By mfitzner
      Cranks after installing a jumper wire to ignition switch to get power but will not start
      Have spark and fuel pump runs
    • By Jeff freeman
    • By JohnnyB
      My Massimo 500 will not start. I’ve checked all the obvious things. It turns over just fine. fuel, spark, fuse box are all good. I can’t figure it out. Any ideas would be greatly appreciated. Thank you.
    • By BWF
      I have a 2011 or so Landmaster LM200.  I cannot get it to start.  I turn the key and nothing happens.  The brake switch seems to be working, the ignition switch works.  The Coil is new the Voltage Regulator is new and the starter relay is new.
      I can connect the terminals on the starter relay and it starts right up and runs fine.  I just can't get it to start by turning the key.
      I am having a bit of trouble bleeding the brakes, not much fluid comes out at the calipers when I am pumping the brakes, though that an air bubble near the brake switch might make it not sense that the brake pedal is depressed.
      I am at a loss, please help!
      Brad
