Just for the halibut if you're still having issues,
Check your battery cable connections on both ends, frame and battery. May want to slightly loosen the bolts just enough to rotate either end a little then tighten them back up again. Do the same with the start wire.
 Worse case would be the starter going out? Rare but does happen.Have a garage check it out?
    • By Adrian Domingues
      Thanks for your help
    • By mfitzner
      Have spark and fuel pump runs
    • By Jeff freeman
    • By JohnnyB
