Husqvarna 4421G
Go to solution Solved by Jim Kessell,
I'm working on my neighbor's Husqvarna 4421G side-by-side.  I think the year is 2007.  The rear wheels won't pull but they do spin when I have it up on jack stands.  With the transmission in neutral, I can turn either rear wheel by hand and neither the other wheel turns nor does the drive shaft turn.  Parts diagrams are sketchy and parts are largely unavailable, so I'm reluctant to tear into it without some idea of where the problem actually is.  Anybody have any experience with these?
  • Solution
Make sure that the gear box has the correct fluid in it.  Mobil 424 which is a Hydraulic/Transmission type fluid.
It won’t engage correctly if you use anything else.
Jim
06 - 4420
  • Popular Now
    • By Silent3923
      Been waiting over a month and a half for a transmission from bobcat,  they claim the polaris transmission is different.   Can anyone verify that???
    • By dilger
      Transmission vent leaks oil out of it after using
    • By OBL
    • By Jeff freeman
    • By AaronD1982
