Hi, im new to utvs and the board but eager to learn and contribute.
My name is Matt,live in Ontario and most experience is with small engines and a old tractor.  I was recently given a older sportsworks 4wd-653.  Had lost the battery on trail, pulled wiring harness then stuck in a barn until now.
Got it all rewired,fluids,plugs,etc and running,its in great shape actually but was leaking fuel from overflow tube under engine shield.
I pulled the carb,am putting it back together....first time doing that so I thought a great time to join a board, I am always eager to learn from others and pass on that knowledge to others.
Thanks for allowing me to join the group
  • Popular Now
    • By Kyler
      Put new fuel in this thing, new battery I can get it to turn over but want stay running it’ll try to run with starting fluid but shuts right back off what could the problem be?
    • By MilSurpYinzer
    • By Eman85
    • By Xov
