Quote
I have a 2006 cub cadet 4x4 trail with transfer case brake assembly 661-04019, I have found a new assembly but not replacement pads. Can pads be purchased or will the assembly have to be replaced
    • By OBL
    • By Bucky4444
      Has anyone found a decent replacement for the factory mirrors on a 2020 1100C?  My 2011 1100 and 2020 1100C both have the same mirrors and Kubota hasn't made one improvement to the design during those years.  Haven't checked the newer models so maybe Kubota finally woke up. Mine are definitely in need of improvement.  .
    • By Kyler
      Put new fuel in this thing, new battery I can get it to turn over but want stay running it’ll try to run with starting fluid but shuts right back off what could the problem be?
    • By Hoppy one
      I replaced the stator on our Bennche 500 because it was not charging. It ran as long as you kept the battery charged. I replaced the stator now it’s not firing. The only problem I found was a wire in the new stator for the crank position sensor was in the wrong place in the plug. I switched it around but still no fire. Putting a meter on those wires and cranking the motor showed no voltage from the crank position sensor. Something I did or a bad “new “ part? Thanks for any ideas.
