It looks bad, but the HISUN (Axis) 500 at work has had "regular" oil in it for 900 hours now.  I discovered it when I googled what my Sector 750 uses, it being about time for the first oil change.  This is the only side by side that the mechanic at work takes care of, and he's the type of person who knows it all.  He would never check an owners manual or search something online.
The problem with someone who knows it all is all you get is what he knows.
Being on a first-name basis with the HISUN Tech Team, I've asked them what the consequences might be.  I'm concerned that the clutch may be permanently damaged.
Anyone had this experience?
I have suggested switching to JASO-MA2 oil and new filter twice,  once to purge the bad additives and the second to keep using the right oil, and hope that we can keep using the UTV, even with the slipping clutch, since everyone using it is used to it.
Actually, everyone but me is clueless to there being an issue.  But, then, I have a Sector 750, so am more familiar with how it should operate.
Second option is to replace the clutch, if Option 1 does not work.
I'm guessing using the wrong oil is not uncommon for UTVs bought at Lowes and Home Depot and farm supply stores.
21 minutes ago, Joe Breaux said:
I know a couple people who ,know it all, and used full synthdtic automotive oil and the clutch failed in a short while.One guy put STP additive in his and it went in the same day.
That pretty much applies to the one I'm referring to.  This clutch is slipping, but still grabbing.
It's a machine that's used every day in golf course maintenance.  I don't believe they've gotten around to switching out to JASO MA2.
When a new clutch it is supposed to be soaked in the correct oil for 24 hours. So maybe changing to the correct oil and a few oil changes will prolong the life of the clutch. But I will probably need to be changed in the near future.
When changing the oil. Disconnect the hose at the top of the radiator that goes into the oil cooler. Do not use an air compressor. Just use your lungs and blow the oil out of the cooler back into the engine. Then hook up the hose back to the tube and unhook from cooler. To blow the oil out of the tube. You'll get most of the bad oil out that way. If you do use an air compressor be careful and remember I told you not to use the air compressor.
Good luck.
  • Haha 1
    • By esmarkey
      Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in.  It still acts like the belt is slipping but now I am thinking it is the clutch?
      Can the clutch be rebuilt?
    • By Burk
    • By Kierobi
