On 9/6/2025 at 12:08 PM, Murphy said:
How to figure out the VIN number. Need the motor size
LWGMHWZOXBA001525
I don't have any problem "talking to" the tech team in Texas.  Reach out by phone to open channels.  I have three names in my emails, if you need to ask for a person.
Since there are so few dealers, or repair shops willing to do work with HISUN, and since so many are sold by Lowe's and Home Depot and farm supply stores, they have helped me do some DIY repairs.
https://vpic.nhtsa.dot.gov/mid/home/displayfile/a430e646-cb41-4963-9cd0-535c59122197
FWIW, your motor type is the seventh character, Z, the same as my Sector 750, but I don't know if that means size or gas.
    • By jertex
      I have two questions:
    • By jon pino
      having trouble with a 2013 uxv500i. have replaced stator due to bad pulser coil. new unit does not work. manual value for pulser coil is 100ish ohm, measured value is 500 ohm. can anyone with one of these fuel injected later model units check their pulser coil with an ohm meter for me? left side of engine small connector next to 3 yellows. jon 605-545-7040
    • By jamesxevan
      I’ve been eyeing a Hisun 500 soft cab enclosure upper doors setup for my UTV, but I’m really not sure if it’s a smart move. The idea of doors and some protection sounds appealing, but I worry they might just be a flimsy afterthought — weak zippers, thin plastic windows, maybe leaking or fogging when wet or cold. What good is “protection” if it doesn’t seal well? Also concerned about ventilation: with soft doors, does the cab get too muggy or stuffy?
      Anyone here use soft-cab doors on a Hisun 500 — did they actually hold up for real riding conditions, or did you end up ditching them for hard doors (or no doors)?
