L3 starter problem
By BWF
I have a 2011 or so Landmaster LM200. I cannot get it to start. I turn the key and nothing happens. The brake switch seems to be working, the ignition switch works. The Coil is new the Voltage Regulator is new and the starter relay is new.
I can connect the terminals on the starter relay and it starts right up and runs fine. I just can't get it to start by turning the key.
I am having a bit of trouble bleeding the brakes, not much fluid comes out at the calipers when I am pumping the brakes, though that an air bubble near the brake switch might make it not sense that the brake pedal is depressed.
I am at a loss, please help!
Brad
By Garjess
My rtv 1140 won't turn over. I've jumped the neutral switch, and the brake switch, and checked the ignition switch. I'm not getting any power to the trigger wire on the starter solenoid. It starts fine with the key on and putting power to the trigger wire on the solonoid.
Does a 2010 RTV 1140 cpx have a starter relay?
Does anyone have a wiring diagram?
By AaronD1982
I recently purchased a 2019 or 2020 (no manual) Massimo 400S Buck Series UTV. It ran fine for a couple days but the low battery light was flashing while it drove. It then died in the field one day and I was able to jump the battery and get it rolling enough to get back to the barn. It started both times I turned the key for a couple days after and when driven died 10 minutes later in the driveway. Even after jumping it had no juice, but with the key out of the ignition it kept trying to start, a quick look on the Google machine and it suggested starter solenoid or ignition switch was the culprit. Fair enough, let's just order a replacement solenoid, right? No way Jose....the pin connector on the UTV is a 2-pin white plastic connector and the part received is a 4 pin. How do I swap that and make it work? Can I even? Where do I find correct parts in the future?
By Timbo
I never see videos of hear of people taking these things to the big trails. Do you ? I just got one and want to.
